What is the best way to Bypass the MMU when using flexibles
tre4b
(@tre4b)
What I have been doing is turning off the MMU on the printer.  Then using a Printer profile in the slicer that does not have the MMU.
The challenge is that everytime I try to change back to the MMU the feeding goes insane.  I spend hours trying to get it to work, then I succeed and it all works perfectly again until the next time I try and bypass the printer.
I wondered if there was an official way of doing this that perhaps I am missing and doing wrong?  What mechanisms have others used for this, and does the MMU reliably work again after reverting back?
Publié : 01/07/2024 9:57 am
Zwirbel
(@zwirbel)
Membre
RE: What is the best way to Bypass the MMU when using flexibles
I do the exact same thing when doing a single colour print (turn of MMU3 and bypass it), then use a non-MMU profile. Getting back to MMU3 works without problems and I don't have to calibrate / change anything else...
Publié : 02/07/2024 11:35 am
1 personnes ont aimé
tre4b
(@tre4b)
Hmmmm,
I wonder if it is because I was using flexible materials.  Part of the challenge is that getting a flexible to load is difficult.  I think maybe I have to turn off the Filament Sensor too so that the extruder no longer autoloads.  I may have been trying to set the filament sensor on too much of a knife edge to allow me to autoload the flexible and use the MMU.
Publié : 02/07/2024 12:45 pm
Zwirbel
(@zwirbel)
Membre
You did not write that you are using flexible material. For flexibles, just additionally turn of the filament sensor and loosen a bit the screws of the idler.
Publié : 02/07/2024 1:49 pm
ObedMuro
(@obedmuro)
I needed to print TPU and I faced the same problem as you, since there was no official information, what I did was first unscrew the PTFE tube that goes to the hotend, I deactivated the filament sensor and the MMU3, but I had the problem that not having The sensor, the nextruder, kept on pushing filament and it became a mess. I tried again by removing the festo fitting and the print came out fine. I don't know if it had anything to do with it. My reasoning told me that it was due to the sharp burr on the Festor fitting without the PTFE tube it jammed the TPU filament, the print went well, but it is something I would not like to do again, then I reconnected everything as it was and the MMU3 had no problem.
Publié : 16/07/2024 8:20 pm
