Straightening filament.....
iftibashir
(@iftibashir)
When loading filament into the MMU3, Prusa recommends straightening the filament from its natural curl as much as possible, which is understandable. However, I find it rarely straightens very much - do you use any tool or anything in particular to help straighten the few inches or so at the end prior to loading?
Napsal : 12/02/2025 12:19 pm
iftibashir
(@iftibashir)
RE: Straightening filament.....
Guess no-one uses anything?
Napsal : 17/02/2025 12:06 pm
RedJacketPress
(@redjacketpress)
I think, at first, I was much more careful about trying to straighten the filament and make sure it was cut at a proper angle for loading into the MMU -- I feed from a dry box, into an enclosure, and it has to pass through a few fitting connectors along the way, and that's where I find it often catches. But over time, I've been much less attentive -- I find if I can pass it through the fitting connectors, everything works, and I can apply a small amount of force if the MMU doesn't catch it.
As to straightening, I just pull the filament between pinched fingers a few times, and that seems to be enough.
Napsal : 12/03/2025 5:07 pm
2 lidem se líbí
Foggy123
(@foggy123)
https://www.printables.com/model/4385-lmgts-filament-straightener
this seems to work pretty good.
Napsal : 16/05/2025 3:16 pm
2 lidem se líbí
