Cold pull on MK4 with MMU3
Comsat
(@comsat)
How do you perform a cold pull on the MK4 with a MMU3. I started the wizard, put a pice of PLA in the extruder but loading filament is stuck on waiting for temperature while temp is at 215•, just waiting
Best Answer by Zwirbel:
Without having tested it: Turn of the MMU3 in the menu on the MK4, then just perform the normal procedure on cold pull described by Prusa.
Postato : 31/05/2024 1:21 pm
1 persone hanno apprezzato
Zwirbel
(@zwirbel)
Utenti
RE: Cold pull on MK4 with MMU3
Postato : 04/06/2024 7:49 am
Comsat
(@comsat)
I will give it a try
Posted by: @zwirbel
Postato : 06/06/2024 5:39 am
Comsat
(@comsat)
This works indeed 👍
Posted by: @zwirbel
Postato : 16/06/2024 10:36 am
