Better options for clearing unloading errors on spool join
Intveltr
(@intveltr)
I've noticed that the unloading process during a spool join operation is a bit hit-and-miss; sometimes it works, but pretty often the MMU3 will fail to unload the remaining filament of the spent spool into the tube.  The only option is to try again.
It would be nice to have a second option to select on-screen: disengage the MMU3 drive, remove the feed tube to the Nextruder, then manually confirm the tube is clear and reinserted.
Opublikowany : 07/10/2024 1:54 pm
