Adding MMU3 to Core One+
ChiTownGuy
(@chitownguy)
My Core One+ will be delivered on Wednesday.  I took the MMU3 off of my MK4S to put on the the Core One+ and then I will add the CoreBoxx Premium from printables.com ( https://www.printables.com/model/1178997-prusa-core-one-coreboxx-premium).
Does anyone have any suggestions or advice for the upgrade?
Thanks...
Opublikowany : 29/12/2025 10:42 pm
LarGriff
(@largriff)
If you had it working on a MK4S, then you know the main thing to watch out for is to avoid sharp bends in the tubing lines.  Excessive friction is the most common problem, but easy to resolve.  The C1+ installation adds longer tubing and a fairly sharp bend leading into the Nextruder, so it is even more crucial to eliminate friction elsewhere as much as possible.
Maybe next year we’ll see a viable alternative with the INDX, but for now that’s still vaporware.
This post was modified 4 months temu 2 times by LarGriff
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Opublikowany : 30/12/2025 3:26 pm
David Holland
(@david-holland)
RE: Adding MMU3 to Core One+
<bluntly> FWIW, My opinion only....
Avoid the CoreBoxx until you're sure the CoreOne is good...
Unless you've got a lot of room, and can keep the CoreBoxx sitting off to the side, it <significantly> impacts the serviceability of the CoreOne.    Once you've had a C1 for a while its (IMO) kind of obvious Prusa presumed that you could pop the top off for extruder servicing reasons.    The coreboxx cables (even w/ the community MMU cable) aren't really long enough to move it off to the side.   Maybe it could be wrangled around if you've a nice wide desk/table w/ lots of empty space on the side - I don't have it.
I've got a CoreBoxx sitting here.  I took it off, and am going to give my unoriginal dry-box, a side mounted buffer unit, and Prusa's enclosed MMU on top a whirl for a bit. -- that's how much I disliked it.   The coreboxx is a nice idea and all, but eh, no...
FWIW, YMMV....
David
Opublikowany : 01/01/2026 8:47 pm
1 ludzie polubili
ChiTownGuy
(@chitownguy)
Do not buy a CoreBoxx
I am on section 4.12 of the assembly instructions and so far I have encountered not enough of the black counter sunk screws (called bolts in the instructions), the holes on the idler wheels are too big for the provided M3x8 bolts to hold the axles in place, rubber band that are poorly cut and irregular, holes that needed to be punched out, indents that needed to be opened, to mount the Mounting Stations, longer bolts are needed and nuts (which are not supplied) are required, Hard to follow and incomplete assembly instructions, misfitting parts, impossible to install bearings (without a special tool) and now I go to put the Mounting Stations and I find out that I have 2 lefts and a middle and no right. I am going to have to find the STL for the right and print it myself or wait who knows how long for BlueRolls to send me a new one. I have built and upgraded several Prusa printers. Building an entire MK4 or Core One is a way better experience than building the CoreBoxx. I ordered with the inserts installed and it came without them so I had to install them myself. Bluerolls asked me to provide them a video of the parts without inserts??? If the plastic is so bad, what is the electronics going to be like? I feel I deserve a partial refund from Blue Rolls. I'm hope that finding the STL won't be difficult. My whole CoreBoxx experience is that this kit is not ready for prime time. Especially when comparing to the excellent kits that Prusa puts out. To anyone thinking about buying or building the CoreBoxx should reconsider and wait until Prusa releases the INDX system with drybox. I cannot in good conscience recommend the CoreBoxx.
I looked for the STL file and I can only find it on printables for fee. Already paid several hundred dollars for the printed parts, I refuse to pay for the STL's to print a missing part.
Opublikowany : 06/02/2026 1:31 am
Butters
(@butters)
I hope I can ask this with regards to the CoreBoxx. I got premium CoreBoxx but first; how do I stack the CoreOne on top of the CoreBoxx as so it holds the weight ?
As well, what type of poly-carbonate size and thickness must I use; as I searched the installation guide but can't exactly find this information ?
Opublikowany : 11/02/2026 9:58 pm
David Holland
(@david-holland)
All the pictures I've seen have the CoreBoxx sitting on top of the C1 (hence my maintenance complaints)    I bought my premium kit from BlueRolls too (which had a few missing screws, a busted part, but not issues as bad as ChiTownGuy's), and the poly carbonate sheets aren't particularly thick, 1/4" mebbe.
Not a chance I'd put the C1 on top of the Boxx, even if it held the C1 up, I don't think it'd provide a particularly stable platform once a print was started..  😮
Opublikowany : 11/02/2026 10:38 pm
ssmith
(@ssmith)
The COREBOXX is designed to sit on or next to the C1; the INBOXX has an aluminum frame and is designed to support the weight of the C1.
Opublikowany : 12/02/2026 12:16 am
Butters
(@butters)
I purchased the wrong one.
Posted by: @ssmith
Opublikowany : 12/02/2026 12:30 am
ssmith
(@ssmith)
Me too... 🙄
Opublikowany : 12/02/2026 12:39 am
Lakwell
(@lakwell)
I also bought a Coreboxx Premium to Blurolls , with 3D Printed parts and semi-smart electronics. A part very few issues on the doc, like you the one regarding the screw vs bolts, I was not facing any issues to mount the coreboxx with the rewinder and semi-smart. Even installing the little program to the arduino was a no-brainer.
I knew the Coreboxx was done for the Core One, but I used it and installed it above my MK3S+ inside the Original Prusa Enclosure.
The issue that I have is to connect the MMU3 to the MK3S+ Einsy board as the original cable is too short, and the one given by Blurolls is only for the Core One.
(MK3S+ doesn't have Gpio on the Einsy motherboard).
I chat to Prusa Help desk but they do not have longer cable for this. so I will try to extend it by adding a wire in the middle.
So to me, no need to say as above "don't buy a Coreboxx"...
even if you are dealing with difficulties, they are not insurmountable or catastrophic.
These kind of "challenges" are manageable, and life keeps going on 😉
Opublikowany : 25/02/2026 2:43 pm
Lakwell
(@lakwell)
for avoidance of doubt, my comment above was a reply to @chitownguy
Opublikowany : 25/02/2026 6:21 pm
