6.2.3-alpha Firmware for Original Prusa MK4, MK4S, MK3.9, MK3.9S, MK3.5, MK3.5S
Jan Kratochvíl
(@jan-kratochvil)
Miembro Admin
Summary
  • Hotfix for the MMU overcurrent
  • Fixed returning to wrong Z position after pause
This is a public release of the 6.2.3-alpha1 firmware for the Original Prusa MK4/S, MK3.9/S, MK3.5/S.
This is an alpha release intended for experienced users. We’ve not been doing translations for changed/newly added texts yet. The features in this firmware are still under development and may not perform as expected. Should you encounter any bugs or issues with the printer’s performance, please report them via GitHub or in our forums.
A recent supply change of a few electrical components has caused issues during the MMU power-on procedure due to the new components having different tolerances.
We have adjusted the MMU power-on procedure to accommodate this change. The current solution is a hotfix that introduces a small (~1s) delay when powering on the MMU. A more permanent solution will be released soon.
We would like to thank you, the community, for your efforts regarding this issue. Your observations and discoveries have made it much easier for us to locate the problem and focus more on how we could fix it.
When unpausing, the printer was not applying the MBL correction to the unpark move.
Release notes:   https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.2.3-alpha1
Respondido : 07/03/2025 10:53 am
1 les gusta
Prusa Slicer
(@prusa-slicer)
Miembro
RE: 6.2.3-alpha Firmware for Original Prusa MK4, MK4S, MK3.9, MK3.9S, MK3.5, MK3.5S
Thanks for sharing the firmware update details! I’ve updated my MK4 to 6.2.3-alpha and noticed some improvements in print reliability, especially with dynamic bed leveling.
For those of you tweaking slicing profiles after the update, I’ve written a guide on adapting PrusaSlicer settings specifically for MK4 & MK3.9 after firmware changes. You can check it out here: 👉 https://theprusaslicer.net/
I’d love feedback or to hear how others are fine-tuning their settings post-update!
Respondido : 07/05/2025 3:47 pm
