Opening up the MMU3 to clear jams ?
kevman
(@kevman)
Is there a way to open up the unit to see if there is a jam between the idler and the toothe gear ? I am having trouble with slot 5 preloading filament.
Postato : 10/02/2025 3:01 am
Rui Guerra
(@rui-guerra-2)
I do that by removing the two screws with springs from both sides of the MMU3 and the top part will basculate towards the rear, leaving access to the tooth gears.
Questo post è stato modificato 1 year fa da Rui Guerra
Postato : 21/02/2025 2:52 pm
iftibashir
(@iftibashir)
RE: Opening up the MMU3 to clear jams ?
As noted above - very easy to open. Just bear in mind the screw positions, and do not tighten down when closing - the screw heads should align just above the notch so that the springs have space to work.
Postato : 26/02/2025 10:24 am
kevman
(@kevman)
what a fantastic word I have never heard before! "basculate"
Thanks! that worked.
Posted by: @rui-guerra-2
Postato : 26/02/2025 2:20 pm
1 persone hanno apprezzato
Rui Guerra
(@rui-guerra-2)
Posted by: @kevman
LOL.
So, instead, read "open to the rear side"
Postato : 26/02/2025 3:36 pm
