MMU3 Continues to print on wrong position or in the wrong size after a solved fila-error
Sethril
(@sethril)
Membre
Hi
I'm not sure how best to describe this. 😔
After various filament errors (fila-stuck etc, it doesn't matter) the MMU3 (MK4) either continues to print at the wrong position or in a wrong scaling.
I checked each layer in the PrusaSlicer, nothing wrong there. I also tested with several different print files, it doesn't matter.
The filament errors shouldn't have anything to do with it, I guess that are my faults. (wrong Settings, Protopasta)
It now happens after practically every second Filament-Error.
Wrong position:
As if the X or Y axis were suddenly offset.
After solving the filament issue, it prints offset. As if the coordinate origin of X and Y is no longer in the middle of the print bed.
With "luck" it prints over another object (see picture 1), no luck: in the middle of nowhere : spaghetti party.
Incorrect scaling:
The printer continues to print in the right place, but in the wrong size.
As example: I enlarged the original object from 100% to 120%, sliced ​​and exported it correctly, it prints in 120% as it should, but after the error it suddenly continues in 100%.
Wrong Scaling after filament stuck:
I can't get any further here, and I'm despairing and have no idea why it happens, or what I could try.
Since I have the MMu3, I haven't made one print without an issue.
I appreciate any tip or help 😭
Using Prusaslicer, MK4, MMU3, ObXidian 0.4 Nozzle, different types/brands of PLA
Publié : 11/06/2024 12:28 pm
JohnnySombrero
(@johnnysombrero)
Membre
RE: MMU3 Continues to print on wrong position or in the wrong size after a solved fila-error
Sorry, I don't have an answer, but just started experiencing this myself recently on larger prints.  I'm in the Original Prusa Enclosure, and thought the tube holder was causing the problem, but it persisted.  Its always on filament "2" for me.
Publié : 18/11/2024 12:38 am
JohnnySombrero
(@johnnysombrero)
Membre
I replaced my "filament two" with a different roll, (Inland PLA+ vs Inland PLA standard) and removed all of my tubes and re-routed them; finally had a successful full size 10+ hour print with 300+ tool changes, no extrusion errors.
Publié : 18/11/2024 7:26 pm
