Firmware 3.0.4 doesn't seem to have a way to select type of filament I'm loading
idcstf
(@idcstf)
Hi All,
I just updated my MMU3 firmware and it appears the Preload to MMU (advanced) setting has been removed. I am getting an Filament Does Not Match error from PrusaConnect. Anyone else having this problem? Is there a fix?
Thanks Ahead,
Ian
Opublikowany : 11/04/2026 2:51 pm
vhubbard
(@vhubbard)
RE: Firmware 3.0.4 doesn't seem to have a way to select type of filament I'm loading
The loading procedure changed.  See https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-general-discussion-announcements-and-releases/3-0-4-firmware-for-mmu3/#post-787304
Opublikowany : 12/04/2026 1:03 pm
Mike B
(@mike-b-3)
Posted by: @vhubbard
This procedure is exactly what used to be called "Advanced Load to MMU" (something like that - it had the word "Advanced" in it, but I can't find the actual menu label now that I've upgraded).  So it got renamed, not changed.  The other loading procedure many people were using must have been deleted.
Opublikowany : 13/04/2026 7:15 pm
