Color bleed
I was attempting to print the sheep in white for the body and black for the face and feet. I am getting color bleed into the white from the black. Anyone know how to reduce this when using white? Filament temp? Something else?
Opublikowany : 20/04/2024 7:11 pm
RE: Color bleed
You need to increase purge volume after the black filament. On PrusaSlicer click "Purging volume"; select "Use custom project-specific settings" and increase the value "from" black to.
Opublikowany : 21/04/2024 7:41 am
1 ludzie polubili
RE: Color bleed
This might be unpopular, but download Bambu Slicer and setup your colors in there. It does an automatic purge calculation. You can then use the purge values in Prusa Slicer. I have never had an issue with the values in Bambu Slicer, where the Prusa Slicer values are woefully inadequate.
Opublikowany : 21/04/2024 3:18 pm
1 ludzie polubili
