Adding MMU3 to new MK4 kit, any changes to printer needed?
Jeff Lastofka
(@jeff-lastofka)
I have a MK4 kit coming soon and will likely get the MMU3 in a while. When I build the printer, is there anything I should do to be ready for the MMU3 and not have to go back in later for changes? It looks like the only real change to the printer is adding a bowden tube input. Plus I suppose plugging in an MMU3 cable somewhere on the printer. The online instructions don't seem to be updated for the MK4 yet, unless I didn't look in the right place. It looks like the MK3+ version requires a lot of digging into the extruder. I'm hoping the MK4 version gets around all or most of that.
Napsal : 22/08/2023 2:38 pm
1 lidem se líbí
und3dp
(@und3dp)
RE: Adding MMU3 to new MK4 kit, any changes to printer needed?
Jeff, I'll end up at the same destination as you but via the reverse route: MMU3 first and MK4 upgrade later. Yes, there's a lot of digging into the extruder involved in adding the MMU3 (from scratch in my case, as I don't already have an MMU2 on the unit). So like you I'm hoping there won't be a lot of work duplication when it's time for the second of the two installations. It may be a bit too soon to tell yet given that MMU3 + MK4 print issues are still being solved. Here's hoping for a smooth path! 😀
Nick
Napsal : 05/09/2023 3:59 pm
1 lidem se líbí
