Way to seal the buffer to prevent moisture absorption?
CybrSage
(@cybrsage)
Anyone run across a way to seal the buffer to prevent the filament from absorbing moisture while it is sitting in the wallet?  Like a drybox or something that can have dessicant added to kept moisture low.  I am going to use the water soluable filament and am worried about all the time it will spend in the open air using the buffer.
Postato : 30/04/2019 9:28 pm
CybrSage
(@cybrsage)
RE: Way to seal the buffer to prevent moisture absorption?
I am thinking about just shrink wrapping the entire thing and then cut out holes for the festo entrances I have attached.  I am using these beauties!
https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-user-mods-octoprint-enclosures-nozzles-.../mmu2s-buffer-m10x1-ptfe-extension-mod/
Questo post è stato modificato 7 years fa da CybrSage
Postato : 30/04/2019 9:32 pm
