solution for IKEA Lack tables & MK3 & MMU
Stano
(@stano)
Hi I tried this configuration with success :
because PINDA is upside down, i put inside selector a small magnet (maybe i need help to modify selector part to add some space for magnet /I used drilling machine 🙄 )...
Posted : 01/11/2018 8:06 pm
Calire
(@calire)
Re: solution for IKEA Lack tables & MK3 & MMU
And for access at MMU2 switchs ?
And to see leds red/green ?
Posted : 01/11/2018 9:04 pm
Stano
(@stano)
access to LEDs/switchs is not problematic - of course it depends how high is placed printer....
Posted : 01/11/2018 9:15 pm
tomcheck
(@tomcheck)
my way 😀
Posted : 06/11/2018 10:51 pm
Martin_au
(@martin_au)
Is there enough clearance for the ptfe tube when near max z-height? I’m struggling getting enough clearance in my enclosure design.
Posted : 07/11/2018 12:15 pm
bidibule
(@bidibule)
my way 😀
Hi Tom,
I haven't done the enclosure because I was waiting for the MMU part but as I see you have "upgraded" your enclosure by extending the lenght of the table stand and review the height of the Plexi?
I saw also you dissambled the commande led unit.
hope to see a clear tuto about this in the next weeks 🙂
Posted : 14/11/2018 11:18 am
Escher
(@escher-2)
Tom, what did you use to raise your table up?
Posted : 25/11/2018 3:54 pm
Lichtjaeger
(@lichtjaeger)
Hi here is my solution.
Posted : 18/12/2018 1:47 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Peter, your "MyMiniFactory" link is not working; best to just paste the link directly 😉
Peter
Posted : 18/12/2018 3:26 pm
Lichtjaeger
(@lichtjaeger)
Peter
Repaired. Thanks.
Posted : 18/12/2018 3:33 pm
Nikolai
(@nikolai)
I just cut a hole at the top. Easy access to the MMU2 😉 and I had/have to access it a lot.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Posted : 22/12/2018 1:46 am
Christian Kuhtz
(@christian-kuhtz)
my way 😀
Tom,
this looks really great. Can you please share the supports for the tube?
Thank you,
Christian
Posted : 05/01/2019 11:55 pm
Ruedli
(@ruedli)
A mirror above the MMU2 under the LACK table allows easy overview of the filament loading.
I had trouble seeing the PTFE tubes, for e.g. manually inserting a filament to change colours of a multi material print. I needed this when loading more then 5 colours. If you can separate colour usage in the Z direction, then using two or more colors is not a problem, provided you swap them mid-print.
Also for inspecting it is good to see the MMU2 from above:
This is now the view from the front of the Lack cabinet, you can clearly see the PTFE tubes:
Finally a second mirror in front of the unit allow inspection from above: while I insert filament:
This view is shown here, obviously the topic of interest is a bit "further away":
Posted : 07/01/2019 12:12 pm
Ruedli
(@ruedli)
The second view, from the top this time, looking at both mirrors...
I used cheap 150x150x1.7 mm mirror tiles, they were 4 for 2 Euro.
My Lack has10CM feet extension.
The mirror holders are printed. Find them here at Thingiverse: https://www.thingiverse.com/thing:3339816
Posted : 07/01/2019 12:16 pm
Ruedli
(@ruedli)
Well, I have 10cm extra feed in additiion to the LACK legs and I have a longer PTFE tube, so it bends forward at high Z values. I finally planne to mount the MMU on top of the LACK table, which is why I am working with longer PTFE tube. I did modify the firmware (and made it available by putting a pull request to MMU sw 1.03) because the unloading did not take into account the (longer) length properly. Also I increased speed for loading/unloading, so theextra length is hardly noticeable.
Posted : 08/01/2019 2:33 am
trv
 trv
(@trv)
RE: solution for IKEA Lack tables & MK3 & MMU
I have a different approach for a LACK enclosure with the MMU.   I posted details on the MK3 forum page here:   https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-user-mods-octoprint-enclosures-nozzles-.../official-3d-printer-enclosure-from-prusa-research/paged/6/#post-138633
Only now do I realize I probably should have posted it here in the MMU forum.
It mounts the MMU on the top, side of the enclosure for easy access from the enclosure front to clear jams, etc.
This post was modified 6 years ago 3 times by trv
Posted : 08/05/2019 9:40 pm
Dajosco liked
Felix
(@felix)
Did a big rig that I wanted everything in. But when the rig was finished I immediately noticed that it was not optimal for the room so I made it smaller and only for the printer. More pictures soon.
Attachment removed
This post was modified 5 years ago by Felix
Prusa MK3S MMU2S
Posted : 11/05/2019 9:27 pm
Felix
(@felix)
Small
This post was modified 5 years ago 3 times by Felix
Prusa MK3S MMU2S
Posted : 11/05/2019 9:35 pm
michael.s186
(@michael-s186)
Well, and that's my way. 🙂
I have two MK3S MMU2S  (at work and at home):
They look similar because they benefit from each other's developments.
Both uses 8mm plexiglass. The black one has only a front and back door, but the top is detachable.
The white one is not detachable, but has doors at every side. Reason: 8mm plexi is astonishing heavy. 😳
The spools are in a self made drawer. They sit on printed rollers with bearers inside, held by metal rods.
The tubes go to drill holes between printer and glass of the rear side.
The black one has a ceiling height of 55cm. It's the absolute minimum if you decide to leave the MMU2 at the intended position.
The tube touches the ceiling slightly at the top most position of the extruder.
Posted : 12/05/2019 10:03 pm
CybrSage liked
