One Way Valve for filament (check valve)
Printschnitzel.at
(@printschnitzel-at)
Hey there!
I have made a check valve for filament with the balls of an 608 bearing.
You can use this for your MMU setup.
https://www.thingiverse.com/thing:3314526
Cheers,
Richard
Napsal : 27/12/2018 11:13 am
1 lidem se líbí
richard.l
(@richard-l)
Member Moderator
Re: One Way Valve for filament (check valve)
I'm confused. What is this for exactly?
Napsal : 27/12/2018 5:56 pm
Martin_au
(@martin_au)
It's a really nifty way to stop filament moving back to the spool when used with an MMU. It would replace the dual lever system Prusa uses.
Napsal : 28/12/2018 4:26 am
Printschnitzel.at
As Martin said, but this is meant to be a concept. You can use the idea for your own filament spool system. I am working on some compact and airtight solutions for MMU where I use this and it's working perfectly.
Napsal : 08/01/2019 12:09 pm
CybrSage
(@cybrsage)
What happens to the unloaded filament if it has nowhere to go?
Napsal : 11/01/2019 12:27 am
could you change the file to have a solid top, no insertion hole, no screw hole, then print 3/4 height, pause, insert ball, resume and print top, covering the ball and preventing escape?
Joan
Napsal : 11/01/2019 12:39 am
1 lidem se líbí
Nikolai
(@nikolai)
Why don't print the solid plastic ball in place and have a solid top without pausing anything? 😉
With MMU you could even use different plastic for the ball 😈
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Napsal : 11/01/2019 1:13 am
I think surface detail may disadvantage that option.... however, a roller, might work!
Joan
Napsal : 11/01/2019 1:18 am
1 lidem se líbí
Nikolai
(@nikolai)
Go higher in resolution for this layers and the surface might be even beneficial for this purpose. But we think in the same direction 🙂
Often linked posts:
Real Multi Material
Napsal : 11/01/2019 1:48 am
Napsal : 11/01/2019 1:58 am
Printschnitzel.at
Joan
Yes, I'll do that 🙂
Napsal : 11/01/2019 8:24 am
1 lidem se líbí
Printschnitzel.at
This does not take care about the unloaded filament.
If you want to use this you'll need some buffer for the filament.
It is meant to be a concept.
I am working on a perfect filament buffer, but it is not ready for publishing yet 😉
It needs to be an airtight system and easy to handle.....
Napsal : 11/01/2019 8:13 pm
Danistra
(@danistra)
wow 😯 ... really looking forward to see the final version. Very impressive. I need this :D. The Prusa solution needs to much space to handle all the filaments and this seems to be very promising to solve that on a reliable way.
Napsal : 14/01/2019 7:40 pm
Printschnitzel.at
There is a new but not final version:
Napsal : 09/02/2019 11:41 am
michael.r52
(@michael-r52)
Here another similar:
https://shop.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles--f57/one-way-l-bracket-t28249.html#p132486
Napsal : 08/03/2019 11:07 pm
1 lidem se líbí
Printschnitzel.at
RE: One Way Valve for filament (check valve)
Teaser of things to come 😏
Attachment removed
Attachment removed
This post was modified před 7 years 3 times by Printschnitzel.at
Napsal : 10/05/2019 6:47 am
