One Way Valve for filament (check valve)
Printschnitzel.at
(@printschnitzel-at)
Hey there!
I have made a check valve for filament with the balls of an 608 bearing.
You can use this for your MMU setup.
https://www.thingiverse.com/thing:3314526
Cheers,
Richard
Veröffentlicht : 27/12/2018 11:13 am
richard.l
(@richard-l)
Mitglied Moderator
Re: One Way Valve for filament (check valve)
I'm confused. What is this for exactly?
Veröffentlicht : 27/12/2018 5:56 pm
Martin_au
(@martin_au)
It's a really nifty way to stop filament moving back to the spool when used with an MMU. It would replace the dual lever system Prusa uses.
Veröffentlicht : 28/12/2018 4:26 am
Printschnitzel.at
As Martin said, but this is meant to be a concept. You can use the idea for your own filament spool system. I am working on some compact and airtight solutions for MMU where I use this and it's working perfectly.
Veröffentlicht : 08/01/2019 12:09 pm
CybrSage
(@cybrsage)
What happens to the unloaded filament if it has nowhere to go?
Veröffentlicht : 11/01/2019 12:27 am
could you change the file to have a solid top, no insertion hole, no screw hole, then print 3/4 height, pause, insert ball, resume and print top, covering the ball and preventing escape?
Joan
Veröffentlicht : 11/01/2019 12:39 am
Nikolai
(@nikolai)
Why don't print the solid plastic ball in place and have a solid top without pausing anything? 😉
With MMU you could even use different plastic for the ball 😈
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Veröffentlicht : 11/01/2019 1:13 am
I think surface detail may disadvantage that option.... however, a roller, might work!
Joan
Veröffentlicht : 11/01/2019 1:18 am
Nikolai
(@nikolai)
Go higher in resolution for this layers and the surface might be even beneficial for this purpose. But we think in the same direction 🙂
Often linked posts:
Real Multi Material
Veröffentlicht : 11/01/2019 1:48 am
Veröffentlicht : 11/01/2019 1:58 am
Printschnitzel.at
Joan
Yes, I'll do that 🙂
Veröffentlicht : 11/01/2019 8:24 am
Printschnitzel.at
This does not take care about the unloaded filament.
If you want to use this you'll need some buffer for the filament.
It is meant to be a concept.
I am working on a perfect filament buffer, but it is not ready for publishing yet 😉
It needs to be an airtight system and easy to handle.....
Veröffentlicht : 11/01/2019 8:13 pm
Danistra
(@danistra)
wow 😯 ... really looking forward to see the final version. Very impressive. I need this :D. The Prusa solution needs to much space to handle all the filaments and this seems to be very promising to solve that on a reliable way.
Veröffentlicht : 14/01/2019 7:40 pm
Printschnitzel.at
There is a new but not final version:
Veröffentlicht : 09/02/2019 11:41 am
michael.r52
(@michael-r52)
Here another similar:
https://shop.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles--f57/one-way-l-bracket-t28249.html#p132486
Veröffentlicht : 08/03/2019 11:07 pm
Printschnitzel.at
RE: One Way Valve for filament (check valve)
Teaser of things to come 😏
Attachment removed
Attachment removed
Diese r Beitrag wurde geändert Vor 7 years 3 mal von Printschnitzel.at
Veröffentlicht : 10/05/2019 6:47 am
