Octoprint and custom tool change in Prusaslicer
x50arm
(@x50arm)
I have an odd issue with Octoprint and custom tool change g-code.  At the end of the print it parks the hotend, unloads the filamen, and then immediately ejects the filament like it would if it sensed running out of filament during a print.  I can run the same g-code directly from the sd card and it does not do this.  I have tried running Octoprint in safe mode and still get the same results.  Anyone here have an idea about what is going on and how to fix it?
Respondido : 10/12/2019 6:07 pm
Davejavu
(@davejavu)
RE: Octoprint and custom tool change in Prusaslicer
Have you setup the printer profile? If you are using Octoprint  1.3.12, they changed things which require a new printer profile for MMU2/MMU2S.
https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-assembly-and-first-prints-troubleshooting/configuring-new-version-of-octoprint-1-3-12-to-load-filament-in-mmu2-mmu2s/
Respondido : 27/12/2019 11:18 pm
x50arm
(@x50arm)
@david-l65
I’ll check what version I have loaded, but I do know mine is set up for 5 extruder with a shared nozzle.  I’m having layer shift issues right now through octoprint, so I’m going to dump and reload octoprint anyway.
Respondido : 28/12/2019 1:10 pm
