Octoprint and custom tool change in Prusaslicer
I have an odd issue with Octoprint and custom tool change g-code. At the end of the print it parks the hotend, unloads the filamen, and then immediately ejects the filament like it would if it sensed running out of filament during a print. I can run the same g-code directly from the sd card and it does not do this. I have tried running Octoprint in safe mode and still get the same results. Anyone here have an idea about what is going on and how to fix it?
RE: Octoprint and custom tool change in Prusaslicer
Have you setup the printer profile? If you are using Octoprint 1.3.12, they changed things which require a new printer profile for MMU2/MMU2S.
@david-l65
I’ll check what version I have loaded, but I do know mine is set up for 5 extruder with a shared nozzle. I’m having layer shift issues right now through octoprint, so I’m going to dump and reload octoprint anyway.
