MK3s R4 extruder MMU2s with path throught coupling
ad.lamy
(@ad-lamy)
As I understand Prusa's choice for one universal extruder, I don't really like the MMU2s particular design, seems like it was designed in a hurry.
I simplified the design and add a path throuhg Festo coupling for a smoother filament path, the filament entry is part of the motor plate holder, adapter-printer-mmu2s and fs-cover-mmu2s are not needed anymore.
The Ir-sensor-holder is now attached on one side to the extruder motor plate.
I did also other minor changes like a removable idler door lever.
https://www.thingiverse.com/thing:3467644
MK4/MMU3 - VORON 2.4 350 Stealthburner
Respondido : 04/03/2019 9:49 am
jwveldhuis
(@jwveldhuis)
Re: MK3s R4 extruder MMU2s with path throught coupling
Where did you get the original designs? Wondering what is needed to customize your design for MK2.5S + MMU2S.
At least one difference is the presence of an end stop trigger as the MK2.5S has mechanical end stop switches for X/Y.
Respondido : 04/03/2019 3:15 pm
ad.lamy
(@ad-lamy)
You can find them here https://github.com/prusa3d/Original-Prusa-i3/tree/MK3S
Respondido : 04/03/2019 7:04 pm
