Buffers vs retracting spool holders
Página 2 / 4
ea69
 ea69
(@ea69)
RE: Buffers vs retracting spool holders
Posted by: CybrSage
I tried to edit the post for the size of the bottom, but it was already too late.  It is slightly over 90mm, not 80mm.  Here is a picture of the customizable_tush_brace.stl from Thingiverse.  It fits perfectly in the bottom of the Rubbermaid 21-cup container.
Attachment removed
I might be able to get down to 90mm. There is a significant slack in the cap and nut and small gains that can be made other places.
Will take a look at it today and see how it goes.
Do you need 65mm spool support, or would 60mm be enough?
Respondido : 16/06/2019 12:42 pm
CybrSage
(@cybrsage)
60 should he good, but if it is no real effort. Make one of each to be sure.
Thanks!
Respondido : 16/06/2019 1:38 pm
ea69
 ea69
(@ea69)
cybrsage,
I have a design for 60mm  spools which is exactly 90mm wide and should fit into your Rubbermaid containers.
Are will willing to print a set and try them out if get .stl files to you?
Esta publicación ha sido modificada el hace 7 years por ea69
Respondido : 17/06/2019 3:05 am
CybrSage
(@cybrsage)
Posted by: greg.h8
cybrsage,
Absolutely!
Respondido : 17/06/2019 6:39 am
ea69
 ea69
(@ea69)
cybrsage,
.stl files are here: https://www.thingiverse.com/thing:3697106
please let me know how it goes.
Respondido : 17/06/2019 3:14 pm
CybrSage
(@cybrsage)
Posted by: greg.h8
cybrsage,
Thanks!  I have 3 hoours of a 17 hour print left, then I will slice and print the stand to see how well it fits.  If it is good, I will do the rest and let you know.
Respondido : 17/06/2019 7:32 pm
ea69
 ea69
(@ea69)
Posted a short video of my rewind solution in use. It shows a rewind to a mostly empty filament spool and a load from a mostly full spool. You can also see that there is no trouble rewinding the full spool thanks to the small rewind that occurs during the loading sequence.
Respondido : 18/06/2019 8:44 pm
Bentonville Heart Lites 3D Printing
(@bentonville-heart-lites-3d-printing)
Posted by: 3dWatsch
Hey gnat!
I presented my buffer system at the Maker Fair Vienna this year and even Mikolas from Prusa showed up and interviewed me on my design 😀
The system is airtight (well, almost), super easy to fill and does not add noticeable friction. It printed 2 days without a single problem at the Fair!
There is still some work to do but I'll put it on thingiverse as soon as I've finished. I can't comment on the reverse systems though.
Here is a sneek preview (starting at 3:30):
Any update maybe on your buffer design?  Is it on Thingiverse?
Respondido : 18/06/2019 9:24 pm
CybrSage
(@cybrsage)
I had a failed print if the stand, but it appears to fit nicely...enough printed for me to know that much.
Now to try again.
Respondido : 18/06/2019 10:39 pm
RAH1
 RAH1
(@rah1)
Ikea Samla boxes come in many sizes.
Width: 15.25"/39cm
Depth: 11"/28cm
Height: 11"/28cm
Or you could make them fit the next bigger one: 22" x 17" x 16"
Worldwide convenience is all they offer over Rubbermaid/Sterlite etc,
Esta publicación ha sido modificada el hace 7 years por RAH1
I am the inveterate tinkerer. I can tink up most anything.
Respondido : 19/06/2019 11:05 pm
RAH1
 RAH1
(@rah1)
Posted by: robin.h9
Width: 15.25"/39cm
Depth: 11"/28cm
Height: 11"/28cm
It might even be better to make them as small as one spool.  Then you could arrange them as you wish.
Respondido : 19/06/2019 11:08 pm
CybrSage
(@cybrsage)
Posted by: robin.h9
Posted by: robin.h9
Width: 15.25"/39cm
Depth: 11"/28cm
Height: 11"/28cm
That is why I use the 21 cup Rubbermaid containers. 🙂  You can get them from Amazon.
Respondido : 19/06/2019 11:12 pm
CybrSage
(@cybrsage)
I have some problem where I cannot print at Point 3 layer height. I haven't cleaned my nozzle for some time, so there could be Gunk buildup inside it preventing proper flow.
I am not printing it point to layer height and should have the stand for that rewinder done soon.
Respondido : 19/06/2019 11:14 pm
ea69
 ea69
(@ea69)
Posted by: robin.h9
Width: 15.25"/39cm
Depth: 11"/28cm
Height: 11"/28cm
The version which supports 65mm spools is 12.2cm wide. Three of them should easily fit in that box.
Respondido : 19/06/2019 11:27 pm
CybrSage
(@cybrsage)
Posted by: greg.h8
The bearing cap ends (for the roller) are too small, they easily fall out of the bearings when I press them in (which requires zero effort).  I am now printing them at 105% of their size to see if that makes them fit snugly.
Respondido : 20/06/2019 3:15 pm
ea69
 ea69
(@ea69)
Posted by: CybrSage
Posted by: greg.h8
do you have a set of calipers? if yes, I would love to know the measurement of the printed part.
I am having fits with Simplify3D versus PrusaSlicer on tolerance for small (<8mm) parts.
Respondido : 20/06/2019 3:21 pm
CybrSage
(@cybrsage)
Posted by: greg.h8
Posted by: CybrSage
Posted by: greg.h8
I do not, but I do have a metal rule with mm on it.  I have attached a picture, but it is slightly under 8mm wide.  I printed that in PrusaSlic3r, but am printing the new ones in S3D, since S3D makes is VERY easy to adjust the size by each axis (I increased X and Y by 5%, left Z alone).  I am printing the new parts out now and will let you know in another 10 mins or so.
Attachment removed
Attachment removed
Esta publicación ha sido modificada el hace 7 years por CybrSage
Respondido : 20/06/2019 3:33 pm
ea69
 ea69
(@ea69)
Posted by: CybrSage
Posted by: greg.h8
Posted by: CybrSage
Posted by: greg.h8
Attachment removed
Attachment removed
would be interested to know how the inserts come out when using S3D at nominal size (not 5% over) if you are willing to take the time to run the print again.
Respondido : 20/06/2019 3:41 pm
CybrSage
(@cybrsage)
Just printing the two parrts is about a 15 minute job, so no problem doing it.  The 105% job just finished and it is slightly too big, I could not force it into the bearing hole.  Doing the 100% with S3D now.
Respondido : 20/06/2019 3:50 pm
CybrSage
(@cybrsage)
The print done using S3D at 100% (normal size) is the same size as the ones sliced by PrusaSlic3r, which are too small.  I am now printing them at 102%.
Respondido : 20/06/2019 4:23 pm
Página 2 / 4
