test print?
Mirar
(@mirar)
test print?
Anyone got a library of good MMU2.0 prints and test prints? Or just a single 2- or 5-color test print.
I couldn't find anything good to search for on thingiverse.
(Putting it here since it's "how to I print this?" where "this" is "a good test print".)
Veröffentlicht : 17/11/2018 5:40 pm
Nikolai
(@nikolai)
Re: test print?
Try search keys "color", "colour" and "MMU" in thingiverse. You should get a pretty nice list.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Veröffentlicht : 17/11/2018 7:20 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: test print?
Just search thingiverse for user "cipis" - that's roman.t - and he produces loads of very good models for MMU.
Peter
Veröffentlicht : 19/11/2018 10:49 am
Mirar
(@mirar)
Re: test print?
Yeah, they are very nice. I guess I'll have to engineer my own tests though...
Veröffentlicht : 20/11/2018 5:20 pm
K7ZPJ
(@k7zpj)
Re: test print?
Here is a 5 color test print for the MMU2:
https://www.thingiverse.com/thing:3192133
Veröffentlicht : 20/11/2018 8:47 pm
toaf
 toaf
(@toaf)
Re: test print?
i like making my own test for it because you can make them as little or as many layers as you want. I was a big fan of the 2/5 layer tests.
Veröffentlicht : 20/11/2018 11:11 pm
PJR
 PJR
(@pjr)
Re: test print?
I prefer more layers and usually test with 20mm tall simple objects (cubes and cylinders). You can easily stop the print at any time (by removing the next filament to load and then a reset).
Peter
Veröffentlicht : 21/11/2018 9:57 am
toaf
 toaf
(@toaf)
Re: test print?
I do have allot of dice (30 cm or so)
I am now just getting to the "going higher" stage of testing.
and I still have to change out my rods and bearings before doing a print I will want real nice
Veröffentlicht : 21/11/2018 10:26 am
PJR
 PJR
(@pjr)
Re: test print?
Yeah, unfortunately, early on, I found that I only started to have missed layers at higher levels (maybe after 8 hours printing) which at the time seemed to be heat-related. Not sure about that now, as the more I printed, I found skipped layers lower down. But I think I have that resolved as well now 🙂
Peter
Veröffentlicht : 21/11/2018 2:01 pm
Mirar
(@mirar)
Re: test print?
I was thinking about technical tests like filament switching (1->2, 2->3, 3->1 etc) and how much they need to extrude to do a perfect switch of colour, and if there'll be an air bubble and bad extrusion on the way...
Veröffentlicht : 22/11/2018 8:17 pm
toaf
 toaf
(@toaf)
Re: test print?
peter.122 made one
https://shop.prusa3d.com/forum/general-discussion-announcements-and-releases-f53/purge-calibration-towers-t24562.html#p108045
Veröffentlicht : 22/11/2018 10:37 pm
toaf
 toaf
(@toaf)
Re: test print?
that test print bruce.p4 posted was fine.
500 color changes, flawless.
don't mind the other issue, I haven't changed my rods and bearings yet, come to think about it I haven't changed out my extruder plastic parts yet 😀 maybe ill get to it.
default prusa pla setting with inland pla.
Veröffentlicht : 23/11/2018 2:04 am
