Stringing and lower resolution prints
SapperDoc
(@sapperdoc)
I've been fighting with my printer since I first got it when the Mk2S came out(ordered Mk2 got a Mk2S delivered, preassembled). Every print has clear lines/layers, no matter how high a detail I print. I usually use the ultra detail to get as clean as I can and still have horrible cleanup after the fact. In addition to this, I have stringing on every print. Last night, I had 3 "torture tests fail in the first 5 minutes due to globs forming. I've tried to figure out how to change the settings in PrusaSlicer to no effect. Any help is appreciated. I've been using the factory settings that come in PrusaSlicer (same problems occurred when it was just Slic3r).
Obviously its not exactly the same with every filament, but I'm using some higher level stuff (Filamentum PLA and Prusament PLA) so it's pretty similar.
Respondido : 23/10/2019 5:12 pm
RE: Stringing and lower resolution prints
Words are useless to describe print problems. Post a photo if you want help.
Respondido : 23/10/2019 7:45 pm
