printing problem MMU2
Rubix
(@rubix-2)
Hello everyone.
sorry for my English
here, today I come to appeal to your knowledge because I encounter a problem with the mmu2.
my impressions in multi color are always failures. I use 4 PLA filament and 1 BVOH filament. in the beginning all this passes well but later I'm clogging, it happens after loading the filament. I specify that it is not every time, but 1 time out of 10 or 15 loading.
do you know where it can come from?
what would be my problem?
Do you have the same concern as me?
For info I made a box for the printer, can it come from?
Thank you all for your help.
Veröffentlicht : 08/04/2019 10:17 pm
toaf
 toaf
(@toaf)
Re: printing problem MMU2
dose it mess up if you don't print something without BVOH?
Veröffentlicht : 09/04/2019 12:38 pm
I found there was a lot of friction in the tubing from the MMU2 to the spool holders so I changed the PTFE to 2.5x4mm and used the same for the length from the MMu2 to the top of the extruder...
Veröffentlicht : 09/04/2019 6:43 pm
