MMU2S Auto Switch on runout
Colin Walls
(@colin-walls)
How can I get the MMU2S to automatically switch to another spool of filament unattended when the first spool runs out?
Napsal : 20/04/2020 2:12 pm
kpreid
(@kpreid)
RE: MMU2S Auto Switch on runout
Turn on "SpoolJoin" in the printer's settings menu.
Also note that this working unattended depends on the filament not having a kink at the end that will jam when unloading, which depends on your filament brand (or if you catch it on the last wrap of the spool you can trim it manually). I would assume Prusament spools are made for this, but haven't run one out yet to see...
Napsal : 20/04/2020 2:24 pm
Colin Walls
(@colin-walls)
Thanks very much! I'll give it a go.
Napsal : 20/04/2020 3:25 pm
