RE: Layer Shift
Looks like you are getting multiple layer shifts. First thing I would check is the tightness of the x-axis stepper set screws. I had them loosen on my MK3S and nearly pulled my hair out before I realized it was a simple problem. Unfortunately by the time I saw the "obvious" issue I had disassembled enough stuff to need to redo calibrations.
Postato : 03/07/2020 3:26 am
