how to force one colour to print first
blatti
(@blatti)
Hi there, I print a kind of knob. My experience is, if I print gray first the orange comes out in better quality. Would you have a suggestion how to force the printer to use gray first instead of orange? Prusa slicer should have an option there.
Help would be highly appreciated.
happy printing Stefan
Best Answer by Baklin:
I haven't figured that out completely yet. I can't always change the order of the objects but that could be the way some prints are designed.
A way around that that works for me is to change the names of the object .stl files. Numbering them will load them in the order I want.
And I load that filament that I want to start with as filament 1 in the MMU. Or atleast as the first that you use in that print. When you use filament 3, 4 and 5 load the one you want to start with as 3.
if you can imagine it - if you can design it - you should print it!
Make the impossible - possible!
Publié : 17/08/2021 4:46 pm
You can drag and drop objects into a different order in the pane on the right, they are usually started in order depending on the first instance of each material...
Publié : 17/08/2021 5:12 pm
Baklin
(@baklin)
Publié : 17/08/2021 5:34 pm
blatti
(@blatti)
external perimeter first
does not help either
Publié : 17/08/2021 7:08 pm
blatti
(@blatti)
first filament - first use
thanks baklin - having the right order: first colour goes first, did work for me.
What would be 3D printing without community?? thanks a lot.
Publié : 17/08/2021 7:37 pm
