filament speed
toaf
 toaf
(@toaf)
filament speed
call me a dumbass.. but I cant find speeds for filaments.(or extruder) but im about to start switching materials. and I feel like I should remember where it was.
Publié : 08/12/2018 8:31 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: filament speed
Is that for printing or loading/unloading? At the moment I don't think the MMU firmware differentiates between filaments.
Peter
Publié : 08/12/2018 11:57 am
toaf
 toaf
(@toaf)
Re: filament speed
im just looking for "extruder 5" speed kinda thing. I see temps in filaments...
holy crap if they don't have this.... its a must have....what are they thinking.
unless there is a game with volumetric speed...
Publié : 08/12/2018 12:02 pm
PJR
 PJR
(@pjr)
Re: filament speed
Yes, volumetric speed should limit the print speed.
Peter
Publié : 08/12/2018 12:05 pm
toaf
 toaf
(@toaf)
Re: filament speed
that just doesn't seem right...
hmm I want to print some flex. so I should speed it down by like 80%....
hmm
Publié : 08/12/2018 12:09 pm
PJR
 PJR
(@pjr)
Re: filament speed
Maybe set max volumetric to 2 or 3 mm^3/s
Peter
Publié : 08/12/2018 12:10 pm
PJR
 PJR
(@pjr)
Re: filament speed
Also, under filament/advanced, slow down everything you can - but not the "loading speed at start".
Slow down ramming and purge speeds as well.
Peter
Publié : 08/12/2018 12:11 pm
toaf
 toaf
(@toaf)
Re: filament speed
I might just try that. after my "guest spool" print gets done... I tried a prusa mmu spool holder for the first time today....worse then I thought it was gonna be. found a good bottle 😀
Publié : 08/12/2018 12:13 pm
toaf
 toaf
(@toaf)
Re: filament speed
wonder if kiss has it easier...
Publié : 08/12/2018 12:14 pm
PJR
 PJR
(@pjr)
Re: filament speed
No, it's pretty much the same, but one day I will modify the MMU firmware to properly work with less hard filaments.
I have all the loading/unloading speeds programmed within the KISS material profiles, but again the printing speed is controlled by the max volumetric value.
Peter
Publié : 08/12/2018 3:12 pm
