Wipe tower disapeares when slicing
Hactar
(@hactar)
I recently testet a two color print and aside from some loading issues on the color change everything worked nicely.
Today i tried printing the same part but in a batch of 3. I had to adjust the wipe tower width from 60mm to 50mm to make it fit nicely (but i tested it with the standart values and just the one part as well) and after i slice the model the wipe tower is gone. I also printed the first layer to see if it was just visual but the tower was missing on the actual as well.
Anyone with an idea what is wrong all of a sudden? Using PrusaSlicer 2.3.3 which is the only thing i can think of that has changed to the successfull last print as that was sliced with PrusaSlicer 2.3.0 (i just checked the gcode file). Is there something i can do in version 2.3.3 or do i have to roll back (or on to the 2.4.0 Alpha)?
Veröffentlicht : 22/10/2021 11:14 am
