Thanks for ruining my MMU2S, Prusa
jaychatt
(@jaychatt)
I'm beyond frustrated with this FW roll-out. My MMU2S is now un-usable and I have to resort to unplugging it and running my MK3s+ as a regular printer.
Upgraded to FW verison 3.13 and got the horrible stepper sound of death. I tried to write that register value based on the Github issue and it didn't work.
Downgraded to FW version 3.12.2 and it still doesn't work.
Downgraded to FW version 3.12.1 and it still doesn't work.
No idea what to keep trying and I shouldn't have to work this hard on a production release.
Postato : 22/09/2023 1:43 pm
MikiCab
(@mikicab)
RE: Thanks for ruining my MMU2S, Prusa
I had to same issue. I had to downgrade both the printer and MMU2s to 3.12.2 and it works.  Good luck.
Postato : 24/09/2023 3:52 pm
alehtosalo
(@alehtosalo)
I needed to downgrade back to 106 to be able to hard reset MMU...it was skipping one slot and found instrutions to go way back to previous version. Well, hard reset started working but MMU is fucked still :D. I will NEVER buy anything anymore from Prusa. Only problems for every time you need to update/upgrade something.
Postato : 24/09/2023 5:00 pm
alehtosalo
(@alehtosalo)
It is impossible to understand what hasn been messed up so badly that MMU is not anymore loading any other filament than the first one. None of other are moving even the axle of the gears is rotating. Cannot see properly how well the bearing is pressing the filament but my guess is that there is something wrong with that.
Postato : 24/09/2023 5:33 pm
Bligh Studios
(@bligh-studios)
Utenti
Same boat for me.  I can no longer use my MMU since the update.  I can't roll back to the 1.6 MMU firmware because prusa slicer no longer even acknowledges that it is there.  (Always can not find boot loader device when trying to flash).  I have to disable the MMU to even be able to use it as a single now.  Kinda upset as well, I just got my order of 10 different color PLA's and was going to start a new project.  Guess I'm scratching that idea.
Postato : 24/09/2023 8:11 pm
alehtosalo
(@alehtosalo)
It looks so that indexing of the bearing drum is one step of. None of the reset functions help with this issue. I have now the last FW before the "3" upgrade, but I am not sure if downgrading further will sove the issue. Anyone who can help here?
Postato : 25/09/2023 7:52 am
alehtosalo
(@alehtosalo)
Took a video about the behaviour...this is now version
3_9_3_3556 for printer and
1_0_6 for MMU
Someone from Prusa should now start giving answers, printer is now completely unusable because of this. What revision should I flash to fix this??
Postato : 25/09/2023 3:08 pm
alehtosalo
(@alehtosalo)
Apparently my video is not coming through... I am now having FIRMWARE 3.12.2 (1.0.6) but not even old SW helps with the situation. WTF was put to that 3.0 release that is screwed up the entire board this badly???!?!? PRUSA some answers now!!!
Postato : 26/09/2023 1:19 pm
