Struggling with FINDA and filament loading on my MMU2S upgrade
Sandbender
(@sandbender)
I'm hoping someone can help me with my MMU2S upgrade. I purchased an MMU2S upgrade for my MK3 printer and am struggling with getting it working. I had great success with assembling and using my MK3 printer, but something seems grossly broken with my MMU2S.
I cannot complete the first layer calibration. There are two glaring problems. The first is that I can't get the printer to load any filament. If I run the first layer calibration, it just starts the run without loading filament. Also when this runs the adjustment for the Z axis seems to have no effect. It just jams the nozzle into the print bed (ruining one side) and never lets me raise the Z axis. The know reads a new value, but the nozzle does not seem to raise and continually drags across the print bed.
The other issue is that the printer does not load any filament for this procedure. It is even worse than that. If I try to load filament to the nozzle, it actually unloads the filament. Then asks me which filament I want to load. I tell it, and then it immediately asks if there is filament coming out of the nozzle. But it hasn't even loaded any filament through the MMU2S.
I thought there might be a problem with the FINDA sensor. If I opened the MMU2S idler and manually move the filament through the selector while watching the sensor values, the FINDA sensor reads one the whole time, but the LED does indicate that the FINDA sensor is actually sensing the filament. I opened up the MMU2S electronics and re-seated the FINDA connector. I powered back on and verified with sensor readings that I could see the FINDA sensor detect filament when I manually moved the filament. So far so good. I then went to load filament to the nozzle, and I get the same behavior as before. It thinks it loaded filament when in fact none was loaded. If I then go to look at sensor readings, I again get the FINDA sensor reading one regardless of whether or not there is filament. The LED, however, does indicate the presence or absence of filament so it cannot be a mechanical problem with sensor positioning.
So my takeaway is that the FINDA sensor is working and the connection to the MMU2S board is working. But there is a problem with the MMU2S controller board, or there is a firmware problem on that board. Does any of this make sense to you?
MMU2S FW is 1.0.5.297
Printer FW is 3.7.0-2201
Thanks for your help.
-Pete
Respondido : 22/04/2019 2:38 am
Erik
 Erik
(@erik-3)
RE: Struggling with FINDA and filament loading on my MMU2S upgrade
Have you done the IR sensor calibration? You need to make sure the IR sensor is working properly on top of the extruder or it'll get stuck in a loading/unloading loop until it gives up (2 or 3 tries, I think).
Respondido : 25/04/2019 6:39 pm
JKeay
(@jkeay)
Both the FINDA sensor and the IR sensor need to work robustly and give the correct sensor readings everytime.
It sounds like you attempted the FINDA calibration. You need to get the probe height just right. If it's too low it can easily read '1' all the time and you might sometimes feel lots of resistance when you push the filament in to test it (using the sensor reading as you said). Conversely if it's too high you might get '0' all the time. Test it over and over again to make sure it's robust and friction-less. As I understand it the green LED means the filament is 'loaded' (i.e in the right position in the MMU2S gears and tube - not that the FINDA has detected it).
The IR sensor calibration is detailed in section 7.1 of the MMU2S user manual. As it says inserting the 1.5mm Allen key into the filament path must give clear 1 (in) and 0 (out) readings every time. It it's right only 90% of the time you'll have problem on 10% of your loads. So again test over and over.
I'm not sure about your nozzle crashes.
Respondido : 25/04/2019 10:52 pm
Guillaume Gendron
(@guillaume-gendron)
Hi peter-j16,
I had this issue when I reinstalled my MMU2 unit after I had disconnected it for some single material prints.
In my case, doing the individual filament calibration for filament 1 solved the problem.
Respondido : 04/05/2019 12:24 pm
Sandbender
(@sandbender)
I have calibrated the FINDA sensor and the IR sensor. I think this might be related to the IR sensor though. What I don't understand though is that the FINDA sensor is clearly reading no filament present yet the printer is thinking that material should be coming out the extruder. The only way that could be is if there is a firmware bug. The main CPU is thinking the FINDA sensor sees filament but it does not. It is not asking the MMU processor and just believes there is filament there. It should not be doing this since it was the one that backed out the filament.
I will try to do an individual filament calibration.
Thanks
Respondido : 08/05/2019 3:30 am
Guillaume Gendron
I also noticed that the FINDA status in the support menu is either very late or not updated at all, so I don't rely on it. Better check its led.
Respondido : 08/05/2019 6:02 am
Sandbender
(@sandbender)
I upgraded to the latest firmware and did the filament calibration all with no luck.
There must be something simple that is wrong. Unfortunately, it is clear that the firmware is very dumb and only looks at sensor values at particular moments in time. The FINDA sensor is checked when loading the filament but then is assumed to indicate filament from then on. Even if some other part of the firmware decides to back the filament all the way out. This is obviously a side effect of having such a basic microcontroller for all of this. No way to support more complex code or multi-threading.
I would love to get the MMU2S working, but at this point I would settle for just a printer that works.
Respondido : 11/05/2019 4:58 pm
John Svensk me gusta
RakNoel
(@raknoel)
Every time you do such a large change it is recommended to re-calibrate basicly everything. I allways start by manually calibrating Z, then mesh-bedleveling. If you here remove the steel-plate, use a paper, and you're on guard; the plate should not get damaged.
Had the same issue. In the handbook it says how to calibrate the filament sensor, but from what i read you have alreaddy solved this
[...] Unfortunately, it is clear that the firmware is very dumb and only looks at sensor values at particular moments in time. The FINDA sensor is checked when loading the filament but then is assumed to indicate filament from then on. Even if some other part of the firmware decides to back the filament all the way out. This is obviously a side effect of having such a basic microcontroller for all of this. No way to support more complex code or multi-threading.
The finda does "continuously" read the value, which is needed to detect filament runout during printing. If this is not in place the printer would require humen intervention even if in "spooljoin" mode as the extruder would not notice utill it is too late.
The 8-bit board is still about as complex(but faster) as what got us to the moon. Now given how insanely fast things actually happen, one would think concurrency is not needed, but the ATmega2560 processor is acutally capable of running multiple threads.
So finally:
Calibrate all sensors, and make sure you have not damaged the F.I.N.D.A. sensor. And if the nozzle crashes into the bed, then 1. there should be a paper there during test, and 2. try changing the P.I.N.D.A. height, as it might be too high
Respondido : 11/05/2019 6:43 pm
Sandbender
(@sandbender)
So implemented the LED on the filament IR sensor. I highly recommend doing this. It is very helpful to know if the filament sensor is actually seeing the filament.
I think I may have found the problem thanks to the post here https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-assembly-and-first-prints-troubleshooting/i-am-at-a-complete-loss-mmu2s-fails-to-even-fail-consistently/.
Increasing the extruder idler tension a lot seemed to fix things. The LED let me know the could load to the extruder even with the tighter idler tension. I think that Prusa really needs to look at the firmware and how it responds to this issue.
Respondido : 21/05/2019 5:54 pm
John Svensk
(@john-svensk)
Posted by: karl.w2
Interesting... I have this exact problem, but the IR sensor calibration is ok!
I have spent six hours on this problem with Prusa Support, and I haven't come a millimeter closer to a solution...
I hope to publish a condensed version of my chat transcripts in this forum today, hoping that one of you big-brained people will find what Support didn't. 😊
Respondido : 28/05/2019 6:50 am
Greywolf 55
(@greywolf-55)
Hi everyone,
I had similar problems. After a few days of trying fixing testing...and failing in many different ways I found out that the cable of the FINDA probe did not have proper connection.
When I tested the probe it usually worked but after a while of printing caused different filament retractions, blockings a.s.f.
Finally the FINDA value was stuck on '1' even when completely removed. Only when I wiggled and kinked the cable with a bit of force it would eventually work again.
I now had to bend the cable at a 90 degree angle and fix it with a cable binder to the sensor as a workaround. This is Abit of a drag when the selector moves to the right end.
So eventually I'll ha e to order a new FINDA probe I guess.
Respondido : 28/11/2019 1:04 pm
