Setting the MK3 Printer Setting to MMU2
Hi all,
I assemblied the mulit material upgrade but am unable to see where you can change the printer setting on Sli3r? On the right side of the window, I only see the original MK3 as an option for "Printer". I have updated the software straight from the website and still am having no luck... Any help would be greatly appreciated! What am I missing?!
Thank you,
Opublikowany : 05/12/2018 9:57 pm
Re: Setting the MK3 Printer Setting to MMU2
configuration on menu -> configuration wizard... select the mmu machine from the defaults.
âOne does not simply use a picture as signature on Prusa forumsâ
Opublikowany : 06/12/2018 5:13 am
Topic starter
answered:
Thank you!!
Opublikowany : 06/12/2018 2:27 pm
