Setting the MK3 Printer Setting to MMU2
Katie
(@katie)
Hi all,
I assemblied the mulit material upgrade but am unable to see where you can change the printer setting on Sli3r? On the right side of the window, I only see the original MK3 as an option for "Printer". I have updated the software straight from the website and still am having no luck... Any help would be greatly appreciated! What am I missing?!
Thank you,
Postato : 05/12/2018 9:57 pm
JuanCholo
(@juancholo)
Re: Setting the MK3 Printer Setting to MMU2
configuration on menu -> configuration wizard... select the mmu machine from the defaults.
“One does not simply use a picture as signature on Prusa forums”
Postato : 06/12/2018 5:13 am
Katie
(@katie)
Thank you!!
Postato : 06/12/2018 2:27 pm
