Replacement Control Board
Bruce
(@bruce-5)
I cannot find a replacement control board under the MMU2S spare parts section of the Prusa eShop.  Where can a replacement board for the MMU2S be purchased - will Prusa not sell one?
Postato : 13/04/2020 8:56 pm
RE: Replacement Control Board
Posted by: @bruce-1
I didn't find it in the shop either. maybe prusa cannot deliver. You can find it here:
https://www.igo3d.com/original-prusa-control-board-mmu2
or
https://www.voxelfactory.com/collections/original-prusa-mk3-parts/products/prusa-mmu2s-control-board
or
https://www.amazon.com/-/de/dp/B07R59DVZL/ref=sr_1_1?__mk_de_DE=%C3%85M%C3%85%C5%BD%C3%95%C3%91&dchild=1&keywords=mmu2+board&qid=1586813732&sr=8-1
Postato : 13/04/2020 9:39 pm
Bruce
(@bruce-5)
@karl-herbert
Thank you, I appreciate the links.  I had found the voxel link, but it was out of stock (plus I was concerned maybe it was not legit).  The one on Amazon says Jun 3rd ... oh well guess I have to be patient as that is what I ended up ordering.  Frustrating that Prusa doesn't even show it as a replacement part on their website (even if out of stock).  Thank you again.
Postato : 14/04/2020 12:37 pm
vintagepc
(@vintagepc)
Utenti
It is in the shop (and in stock) but cannot be added to the cart for some reason. You probably need to ask support to let you add one to your cart.
https://shop.prusa3d.com/en/mmu2mmu2s/782-control-board-mmu2s.html
Postato : 14/04/2020 3:21 pm
Tu hanno apprezzato
Bruce
(@bruce-5)
@vintagepc
That's interesting ... from the main page of spare parts I did not even see that.
IS ANYONE FROM PRUSA READING THIS?  Why can it not be added to the cart?
Postato : 14/04/2020 8:16 pm
Bruce,
Please contact Prusa Support, they are your best route to the resolution.
this is a peer to peer support group with little oversight from Prusa folk.
I suspect with the issues going on around the world, at this moment, I suspect they are stretched at the moment
Postato : 14/04/2020 9:15 pm
CybrSage hanno apprezzato
