Quick swap between MMU and Standard setup?
Is there a way to quickly convert MMU MK3s back to a standard setup? I have multiple users coming in to use the printers and I'd like to have the option to use the MMU some of the time, but keep it default configuration most of the time for ease of use.
Napsal : 06/12/2023 4:18 pm
RE: Quick swap between MMU and Standard setup?
When the printer is on, you can disable the MMU on the settings menu im pretty sure or just in the menu just click on MMU (ON)
Napsal : 18/05/2024 4:40 am
