PrusaSlicer and MMU. How do I import MMU .stl files and select colors?
[Rozwiązany] PrusaSlicer and MMU. How do I import MMU .stl files and select colors?
MikiCab
(@mikicab)
Hello Everyone,
It is probably obvious and simple but I cannot seem to figure out how to import MMU .stl and change the colors. Every time I try they end up either all in the center or not aligned correctly.  Plus I cannot seem to figure out how to change the filament selector.
Any help is appreciated.
Thank You
Opublikowany : 25/05/2019 1:40 pm
MikiCab
(@mikicab)
RE: PrusaSlicer and MMU. How do I import MMU .stl files and select colors?
I figured it out how to load the file and change the color from the right side menu.  Can you click on the model and change the color.  I don't seem to be able to do that now.
Thanks
Opublikowany : 25/05/2019 2:05 pm
