PrusaSlicer and MMU. How do I import MMU .stl files and select colors?
Hello Everyone,
It is probably obvious and simple but I cannot seem to figure out how to import MMU .stl and change the colors. Every time I try they end up either all in the center or not aligned correctly. Plus I cannot seem to figure out how to change the filament selector.
Any help is appreciated.
Thank You
Postato : 25/05/2019 1:40 pm
Topic starter
answered:
RE: PrusaSlicer and MMU. How do I import MMU .stl files and select colors?
I figured it out how to load the file and change the color from the right side menu. Can you click on the model and change the color. I don't seem to be able to do that now.
Thanks
Postato : 25/05/2019 2:05 pm
