Problem after firmware update
luggw1
(@luggw1)
I just updated the firmware on my MK3S+ and MMU2S to the latest version and now I'm having issues with the MMU2S.  I get an error when I try to print stating the idler can home properly and it cites the code prusa: 04125.  It tells me to look for obstructions that would keep it from completing its task.  FWIW, it all worked fine before the update.  Also, I found after the update that I had to go into the settings and turn on the MMU, which seemed odd.
Any help with this would be greatly appreciated.
Thanks
Bill Lugg
Publié : 30/11/2023 4:07 pm
1 personnes ont aimé
Jamie Emmart
(@jamie-emmart)
RE: Problem after firmware update
Completed firmware updates 3_13_2_7080 and 3_0_1 on Mk3S+ with MMU2S. Printer updated fine, but MMU2 behaved unusual at startup, and printer was in non-MMU mode. Turned MMU on in settings (thank you Bill) and MMU repeated issue, but advised startup issue with spool and gave me options! Reduced sensitivity from 7 to 5. Now MMU starts up super fast and quiet. Not sure if sensitivity is too low, but can't get back to this setting to test! Oh well.
Publié : 16/12/2023 7:20 am
JuanCholo
(@juancholo)
just updated to latest firmware and suddenly having all kinds of weird issues.
problems with filament loading
and getting SD card errors when loading a file that it is incomplete and should i continue or not.
ARUGH!!! i should have never updated the firmware.
“One does not simply use a picture as signature on Prusa forums”
Publié : 17/12/2023 11:52 pm
luggw1
(@luggw1)
I backdated to 3.12.2 and 1.0.6 for the MMU2s and everything works again.  After the latest update to PrusaSlicer to 2.7.1, I'm getting a notification of a firmware update available, But I'm not trying again until after I upgrade  the printer to an MK4.  I don't need any more trouble with it.
Bill Lugg
Publié : 18/12/2023 12:05 am
JuanCholo
(@juancholo)
thanks i changed to  3.12.2 and 1.0.6
hopefully this avoids whatever hell prusa caused. but now i have no project to test with it as i could not use the machine and went with an alternative.
Publié : 18/12/2023 4:11 am
NovaLindgren
(@novalindgren)
Membre
Since the MMU was disabled after the update, make sure to re-enable it in the settings. This might have impacted the configuration stored in firmware, and re-enabling it can help reinitialize the device.
Go to Settings > Hardware > MMU on the printer’s menu, and confirm the MMU2S is enabled.
Raft Wars
Publié : 25/10/2024 8:51 am
