Printer shuts down after firmware update.
Rob-EU
(@rob-eu)
Yesterday I assembled the MMU2S unit for my MK3s+. I just downloaded the firmare and flashed the printer (Rambo) and then the MMU2s board. Both seemd to work well, But after that my printer shuts down after I turn it back on.
For the Rambo I used this file: prusa3d_fw_MK25S_3_10_0_4481_RAMBo10a_en-nl.hex
For the MMU2s I used this file:prusa3d_fw_MMU2board_1_0_6.hex
Any thoughts?
Postato : 27/07/2021 6:31 am
Rob-EU
(@rob-eu)
second thought about my former post
The printer hasnt been on since I build the MMU2s and put it on my printer. So it might be a powersafe thing? That would mean I connected something wrong I guess. I will look into that now, but still would appreciate any feedback
Postato : 27/07/2021 6:48 am
Rob-EU
(@rob-eu)
Cables checked
All the cables are in the correct place. So there should not be any issues
Postato : 27/07/2021 7:03 am
problems
try disconnecting the mmu power and seeing if the problem persists!
if the problem, still persists, disconnect the MMU data as well.
Postato : 27/07/2021 7:33 am
Rob-EU
(@rob-eu)
Did that
Disconnected the MMU2s completely, now my printer even quicker shuts down. With the MMU it takes a few second, now it instanly shuts down again
Postato : 27/07/2021 7:48 am
Rob-EU
(@rob-eu)
I wonder
I do have a MK3s+. I followed the steps in this manual, step 25. Since step 26 says MK3S\+ (optional), In case you upgraded from MK3 printer, you have to reconnect the entire extruder:
I did not follow step 26 since I bought a MK3s+ and did not upgrade from a MK3. I wonder if my printer is a MK3 with upgrade and it is just called a MK3s+ bacause the upgrades came with it? If so, should I rewire the entire Rambo?
https://help.prusa3d.com/en/guide/6-electronics-and-mmu2s-unit-assembly_44728
Postato : 27/07/2021 8:03 am
Utenti
Posted by: @rob-eu
I would back or downgrade the firmware.  If that works, post your issue on github and notify support via eChat.
Baklin
(@baklin)
title
The firmware you flashen doesn't look like the right one for a MK3s+
I'm not at my computer now, but I think you picked the wrong file if you really have a MK3s+.
I will check later to see what file are in the zip.
Postato : 27/07/2021 8:15 am
1 persone hanno apprezzato
Rob-EU
(@rob-eu)
I think I checked everything
I did check every cables and all of them seems to be in place, I start to regret the MMU because before my printer worked like a charm. Maybe I should take the MMU away and teach it how to swim in the Maas (river close to me 😉 )
I really hope someone can enlighten me about what is wrong with it.
Postato : 27/07/2021 9:01 am
Rob-EU
(@rob-eu)
Baklin was right
He put me in the right track. I did use the wrong file. As shown in my first post I used the one for the 2.5. I feel so stupid now....
But thanks all for thinking with me. And Baklin, bedankt!!
Postato : 27/07/2021 9:17 am
