PrimaSelect PVA+ profile????
nuroo
(@nuroo)
In anticipation of getting the MMU, I bought two rolls of PrimaSelect PVA+ Soluble Support 500g from Prusa's site...
https://shop.prusa3d.com/en/special/169-primaselect-pva-soluble-support-500g.html
Tested and recommended as soluble supports for our Multi Material upgrade.
But I only see a profile in Slic3r for the Verbatim BVOH Soluble support filament.
Can I use the Verbatim pva profile with PrimaSelect pva?
If not will there be a separate profile created for PrimaSelect PVA?
Does anyone have experience printing with primaselect pva. Any tips or suggestions.
Prusa MK3 > MK4s
Prusa MK2.5 kit > MK3 > MK3s > MK4s
Prusa SL1 3D printer + Curing and Washing Machine (day1 order)
Taz6 - taken apart for space
CR10s4 - upgrading
Delta 3ku - dont use
Veröffentlicht : 15/09/2018 11:45 pm
nuroo
(@nuroo)
Re: PrimaSelect PVA+ profile????
Anybody, 2 months later
Prusa MK3 > MK4s
CR10s4 - upgrading
Veröffentlicht : 12/12/2018 5:04 am
JuanCholo
(@juancholo)
i have both BVOH materials the Prima and Verbatim
just use the Verbatim for the prima and adjust as needed.
i used the material for the first time and was very disappointed in the performance of soluble filament.
“One does not simply use a picture as signature on Prusa forums”
Veröffentlicht : 12/12/2018 5:25 am
nuroo
(@nuroo)
I'm giving it a go as we speak on the palette 2 pro. I needed to make adjustments indeed. but in what direction?? who wants to trial and error expensive filament. seems to be working but i'll need to continue tweaking the profile.
Prusa MK3 > MK4s
CR10s4 - upgrading
Veröffentlicht : 12/12/2018 6:43 am
toaf
 toaf
(@toaf)
trying the pva as we speak. seems something is odd with the soluble material profile. I might try the normal profile but its working. purge block is all wrong.
Veröffentlicht : 12/12/2018 7:35 am
toaf
 toaf
(@toaf)
pva default BVOH settings
mk3 optimal soluble setup.
wasn't very high BUT the model is in water now. hitting print one something else
Veröffentlicht : 12/12/2018 8:05 am
PJR
 PJR
(@pjr)
Antient Member Moderator
PrimaSelect had a profile for MMU1; I don't think it has been considered for MMU2 as BVOH was pushed by certain people 🙁
My experience of PVA is that it can be very problematic. It is very difficult to manufacture with consistent diameter and often goes way out of spec. The roll of eSun I tried to use on MMU1 would on occasion, not pass through the cooling tubes.
I ended up trying PrimaSelect which worked OK; I also have an unopened spool of Scaffold.
I did try BVOH on the MMU2, but it's characteristics changed significantly over the course of a 12 hour print, to the extent that it was unprintable at the end. However, that was during a humid period in the (very) hot summer.
Basically, I gave up with soluble supports 🙁
Peter
Veröffentlicht : 12/12/2018 10:03 am
toaf
 toaf
(@toaf)
well im taking 1 for the team. just ordered some PVOH.
but so far so good. kinda had to fight with it for the first few loads. but it seems fine now. I think I should run some proto pasta metals to score out some of the tubes 😀
Veröffentlicht : 12/12/2018 10:08 am
toaf
 toaf
(@toaf)
wow the mmu is so well tweaked. It's running this crappy gizmo dorks neon green crap that tormented me before I got my mmu
Veröffentlicht : 12/12/2018 10:10 am
toaf
 toaf
(@toaf)
hey should pva cool all the way before removing? I swear it took some of my pei off. almost petGish. but maybe it will clean up
Veröffentlicht : 12/12/2018 10:12 am
nuroo
(@nuroo)
2nd pva print seems like a success havent dissolved it yet. Im 95% convinced 1st pva print could have been a success if i didnt have to adjust the primaselect pva profile. That stringy hair behind model is from octolapse moving print head quickly to take a shot - and also untuned pva settings.
@pjr guess i Got lucky. I'm still scared to try on mmu2 but I guess I must now..... What do u guys think of my drybox?
Prusa MK3 > MK4s
CR10s4 - upgrading
Veröffentlicht : 12/12/2018 12:39 pm
nuroo
(@nuroo)
I believe in you Toaf 😀
Prusa MK3 > MK4s
CR10s4 - upgrading
Veröffentlicht : 12/12/2018 12:41 pm
PJR
 PJR
(@pjr)
Well, as you know, I have had huge issues with MMU2 (until I changed the extruder body), so I may try again. However, the best thing to do is to cut off the amount you need and keep the spool in a dry bag.
Peter
Veröffentlicht : 12/12/2018 1:13 pm
Colin
(@colin-4)
I've been playing with some Gizmo Dorks PVA I had laying around from a previous dual extruder clone. I tried the PVOH profile and it was a huge failure. I've had much better luck with the old MMU1 PVA profile.
Veröffentlicht : 12/12/2018 1:22 pm
nuroo
(@nuroo)
ok. Doesn't dissolve as quickly or as easily as i thought.
Also didnt need such a dense support.
Gonna try soluble interface only, next.
Prusa MK3 > MK4s
CR10s4 - upgrading
Veröffentlicht : 12/12/2018 11:26 pm
Colin
(@colin-4)
Yeah, doesn't really dissolve so much as it just gets slimy. But the results are nice. Here's an upside down Benchy. With regular supports this would look terrible.
Veröffentlicht : 13/12/2018 1:38 am
CybrSage
(@cybrsage)
When you get it tweaked in, can you post your profile info?
Veröffentlicht : 14/12/2018 12:16 am
