Please help me troubleshoot the problem
The problem I have is getting the load failed message. Filament is never stuck. The tip is beautifully formed. IR sensor is manually calibrated so that it reads 1 when I manually push the filament between the gears and 0 when I pull it out. During an actual fail, what happens is the filament is loaded to the nozzle, sensor reads 1 without flickering (unless it flickers on a microsecond scale and I cannot perceive it), yet the extruder unloads completely and several cycles like this happen until the machine gives up. Pretty please help!
Napsal : 12/06/2022 7:19 pm
