MMU2s won't load
Tom
 Tom
(@tom-30)
Utenti
MMU2s won't load
The filament loads into the extruder and it does the levelling sequence, after that just before it starts making the starting line, it unloads and then proceeds to try to load again but fails.
Please help 🙁
Postato : 09/05/2020 3:34 pm
RE: MMU2s won't load
Posted by: @thomas-s108
Please help 🙁
I would watch on the LCD display what the sensor does during this phase. If it remains stable on or switches between 0 and 1.
Postato : 09/05/2020 5:03 pm
pcweber
(@pcweber)
Utenti
@karl-herbert
I had a similar error and I fixed it by redoing the sensor adjustment. If it is out of adjustment then it will get a false empty or zero and return the filament to the MMU to start the sequence over again.
Phil
Stay safe and healthy, Phil
Postato : 09/05/2020 7:06 pm
@pcweber
For this reason, I have equipped the extruder sensor with an LED for a better overview. An additional LED for the FINDA is in the works.
Postato : 09/05/2020 9:28 pm
1 persone hanno apprezzato
