MMU2S keeps pushing filament into extruder
danwood82
(@danwood82)
Hi
For some reason my printer has started to push filament into the extruder without stopping and the print will not start, leaving a blob of PLA at the first point on the steel sheet. I've done full calibration, Cold pull, the PINDA and FINDA work and I've even replaced the nozzle.
Please help
Respondido : 12/05/2020 8:47 pm
cgrums
(@cgrums)
RE: MMU2S keeps pushing filament into extruder
This usually happens to me when the IR sensor has not tripped from a steady 0 to 1.
Respondido : 12/05/2020 8:49 pm
kUMters
(@kumters)
MK3S + MMU2S (@BMG + MOSQUITO), MINI, ANET A8
Respondido : 13/05/2020 7:11 am
BanditBBS
(@banditbbs)
Were you able to resolve your issue?  I've been having the exact same issue since upgrading to the latest firmware.  It is indeed my IR sensor not changing to 1 once the print starts, but before that it works as expected.  I can't figure out whats going on!
Check out some of my time lapse prints: https://www.youtube.com/user/BanditBBS
Respondido : 31/05/2020 2:35 pm
@bandit
On the MK3s/MMU2S both sensors communicate with each other. This is also necessary to determine the filament length from the MMU2S to the extruder. If one sensor is not working correctly or gives an incorrect feedback, such errors will occur. Adjust both sensors:
https://help.prusa3d.com/en/article/ir-filament-sensor-calibration-mmu2s_2245
https://help.prusa3d.com/en/article/finda-setup-and-troubleshooting_2250
Respondido : 31/05/2020 2:46 pm
