MMU2s and custom Extruder with IR Filament Sensor
joey
 joey
(@joey)
Dear Prusa Members, please Help 😉
I just got my MMU2s build and mounted. It all turns out great right now. There is just one big issue. I am a big fan of the Skelestruder Extruder Upgrade. I already redesigned parts of it, to fit the original IR Sensor (look on thingiverse and here). i Upgraded the filament path so it slides in very easy but still detects the filament at the extruder very reliable. but there is one big issue, i guess most of the people who read this far know it already. The skelestruder has a bigger gap between the IR Filament Sensor and the extruder gears. i know that the sensor tower has been build to really measure once the filament goes into the bondtech gears. But somehow i prefer to keep it the skelestruder way. Is it possible to change the code to add a little extra extrusion to the loading process to pass the gap between the ir sensor and the bondtech gears ?
Just like a mixture of the old mmu2 without the ir sensor and the new way ? so once the ir sensor sees the filament it moves the filament like 8mm further into the bondtech gears and does not stop immediatly ? at best with a permanenct gcode modification and not a firmware update so it keeps its settings once the firmware gets updated ?
You would help me a lot. cheers
johannes
This topic was modified 5 years temu by joey
Opublikowany : 13/03/2021 11:14 pm
gwydion
(@gwydion)
RE: MMU2s and custom Extruder with IR Filament Sensor
i'm working on an ir cartridge that work for Skelestruder and mimic the trigger point of the original extruder but i haven't lot of time on it for now if you want i can share stl file to get feedback
Opublikowany : 17/03/2021 2:44 pm
joey
 joey
(@joey)
@gwydion
please do so.. if you have a concept you can share the CAD file as well i might be able to help. what CAD are you using ? Fusion 360 ?
Opublikowany : 19/03/2021 6:27 pm
gwydion
(@gwydion)
@joey
yes fusion 360 but i'm still a noob 😉 so i try to get used to it (i can't yet send you pm how can we get in touch ?)
this is the link to the concept i'l still try to perfect the tail of my trigger arm and the pivot fixing point in the idler
https://a360.co/3r3yPop
Opublikowany : 21/03/2021 9:19 pm
