MMU2 testing G-Code for ramming, shaping, and changes
Blackbird351
(@blackbird351)
G-code for quickly testing MMU2 operation, filament swap, and ramming end forming.
Anyone particularly good at modifying g-code?
I think it would be very helpful to have some code that would put the extruder in the middle of XY at about 100mm and run through some purging (air prints) of the startup purge, then go through X# of filament changes with ramming, then the end sequence without having to heat the bed and have a purge block and print layers of an object. I already know the printer prints fine😬
I just want to test the mmu.
I sliced a .2 layer 3 color object to review the code, and while I think I could do this with a bit of research, I figured someone who is into the gcode world could remix it very quickly.
Anyone else think this would help save a bunch of time dialing in the mmu?
Veröffentlicht : 08/04/2019 8:47 pm
