MMU2 Looses (software) connection/communication to Mk3 Midprint
Tenumen
(@tenumen)
I've only recently managed to get my MMU2 calibrated and I've run into a problem with my first main print.
I've printing something using the MMU2 in single mode -just to iron out issues, and about 2hrs into the first print the MMU2 lost connection with my Mk3.
By this I mean that the Mk3 suddenly is running in original software mode, not MMU2 software mode. This means that the extruders in the MMU2 stop moving -jamming the filament. So my Mk3 tried to keep pulling filament and cannot as it's trapped by the MMU2. I wasn't at the printer so when I got back the print had finished but it was an underextruded mess since the last few layers had no filament extruded. The screen said that the print had successfully finished.
I pulled out the orange PTFE tube from the main extruder head to see what had caused the issue and found the filament was still inside. So I tried to unload it and it didn't give me the MMU2 load/unload options, only the original Mk3 ones. Unloading it was just as the original Mk3 -it tried to push it out of the extruder head gears and that's all -the MMU didn't budge -still jamming the filament.
I reset my Mk3 (pressed the big X) and tried again -same result. No connection to MMU2.
So I powered it off, manually unloaded it, then powered it back on.
Now I get the MMU2 options again, so I load my filament back in, and start a print again -works fine....
So -has anyone else had this happen? Any idea of the cause? How can I stop it happening again?
Thanks
Postato : 09/12/2018 9:00 pm
ad.lamy
(@ad-lamy)
Re: MMU2 Looses (software) connection/communication to Mk3 Midprint
I had this issue 3 times since I got my MMU in october, no idea where it came from, but look here https://github.com/prusa3d/Prusa-Firmware/issues/1377
MK4/MMU3 - VORON 2.4 350 Stealthburner
Postato : 09/12/2018 9:40 pm
