MMU2 Homing Error
Flack
(@flack)
MMU2 Homing Error
Just built up my MMU2 to use on my MK3, set it all up, but when I power it on shows all the leds changing and flashing but the carriage is not moving at all. I have flashed the latest firmware to the MMU & the printer but nothing seems to work, have I got a faulty board or motor.
I did notice that when I connect my laptop up to the MMU2 to update the firmware the carriage does move, but once firmware flashed it does not.
Also in the manual it says you can select to install the filament through the Lcd menu, but I have nothing on my lcd thats lists these options. Under the info on the lcd it says MMU N/A.
any ideas please.
Mick
Respondido : 10/12/2018 9:09 pm
Flack
(@flack)
Re: MMU2 Homing Error
Ok my fault after going back and checking my connections inside the printer control box I spotted I had connected the four pin plug the wrong way round ..Doh....
All up and running now just doing a test print.
Mick
Respondido : 10/12/2018 10:34 pm
