MMU Update
Rockies
(@rockies)
MMU Update
A few months ago our printer stopped working.  The MMU unit wouldn't move correctly when starting the printer.  We just stopped using it,  We are wanting to get it started again.  I updated the m3 unit and then needed to update the MMU unit.  The MMU update failed.  I tried and think I succeeded in erasing  the MMU EEPROM thinking that might help. The update still failed.
I have attached the error log.
We will really appreciate any help we can get on getting our printer up and running again.
Thank you.
Postato : 08/12/2019 5:23 pm
Rockies
(@rockies)
RE: MMU Update
This is the start of the error file:
      Using Port                    : /dev/cu.usbmodem14101
                Using Programmer              : avr109
                Overriding Baud Rate          : 57600
                AVR Part                      : ATmega32U4
                Chip Erase delay              : 9000 us
                PAGEL                         : PD7
                BS2                           : PA0
                RESET disposition             : dedicated
                RETRY pulse                   : SCK
                serial program mode           : yes
                parallel program mode         : yes
                Timeout                       : 200
                StabDelay                     : 100
                CmdexeDelay                   : 25
                SyncLoops                     : 32
                ByteDelay                     : 0
                PollIndex                     : 3
                PollValue                     : 0x53
                Memory Detail                 :
                                         Block Poll               Page                       Polled
                  Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
                  eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
                  flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
                  lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                  calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
                  signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
                Programmer Type : butterfly
                Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: avrdude-slic3r: butterfly_recv(): programmer is not responding
avrdude-slic3r: ser_recv(): read error: Device not configured
avrdude-slic3r: ser_drain(): read error: Device not configured
avrdude-slic3r: ser_send(): write error: Device not configured
Postato : 08/12/2019 8:31 pm
Dave Avery
(@dave-avery)
RE: MMU Update
try flashing using a windows machine - the flasher and linux can be problamatic
Postato : 09/12/2019 5:19 pm
Will
 Will
(@will)
Utenti
RE: MMU Update
I recently had this issue as well. The only way that I could successfully flash what to reset the MMU right before I hit flash.. There is a really small window that seemed to work.
Also there was a "bug" that was present in Ubuntu that prevented flashing ... something with modem ... I will try to find the culprit when/if I have a chance today.
Postato : 10/12/2019 3:12 pm
Rockies
(@rockies)
RE: MMU Update
@david-a66
I will try that.  I have run parallels on my mac to have a windows environment for years with out a problem but since there last up date a few days ago I have had to bring up a back up once and think I will need to do it again today.  It has been sitting for about 40 minutes with out starting.  So it may take me a day or two to try using the windows flash option.
Postato : 10/12/2019 3:20 pm
Rockies
(@rockies)
RE: MMU Update
@willima-m26
When you say reset - do you mean the factory reset process?
Thanks for any suggestions and help.
We have had such a great time with our printer.  Want to get it going again.
Postato : 10/12/2019 3:24 pm
Will
 Will
(@will)
Utenti
RE: MMU Update
No sorry I should have clarified that. The button beside the usb port on the MMU.
Postato : 10/12/2019 3:45 pm
Rockies
(@rockies)
RE: MMU Update
Yeah Thank you both for your help.  I used a windows version of slicr and the reset button and got the new firmware loaded.
I really appreciate your help.  Made my day.
Postato : 11/12/2019 2:51 am
