Mk3s+ and MMU2s - hang up at end of print
At the start of the print everything is fine, the MMU pushes filament to print head.
when the print has finished the printer states that there is a color change (not one that i can tell.) pulls the filament back to the MMU askes what filament i want (1-5). when i select the filament it will push the filament to the print head but gets stuck at the sensor and makes noise like it cant push is. I can by hand push it and it will go in.
I had to downgrade the firmware to due to bugs, I have the tune set to 6 but i have tried turning it up but nothing will help.
Printer Mk3s+ (13.4.0) MMU2s (3.0.2) PrusaSlicer (2.9.0)
Opublikowany : 08/01/2025 11:47 pm
RE: Mk3s+ and MMU2s - hang up at end of print
I recommend you update both the printer and MMU2s firmware to the latest version or try a more stable firmware version.
Opublikowany : 14/02/2025 6:39 am
