Mk3s+ and MMU2s - hang up at end of print
Ron L
(@ron-l)
At the start of the print everything is fine, the MMU pushes filament to print head.
when the print has finished the printer states that there is a color change (not one that i can tell.) pulls the filament back to the MMU askes what filament i want (1-5). when i select the filament it will push the filament to the print head but gets stuck at the sensor and makes noise like it cant push is. I can by hand push it and it will go in.
I had to downgrade the firmware to due to bugs, I have the tune set to 6 but i have tried turning it up but nothing will help.
Printer Mk3s+ (13.4.0) MMU2s (3.0.2) PrusaSlicer (2.9.0)
Publié : 08/01/2025 11:47 pm
JarvisWard
(@jarvisward)
Membre
RE: Mk3s+ and MMU2s - hang up at end of print
I recommend you update both the printer and MMU2s firmware to the latest version or try a more stable firmware version.
fall guys
Publié : 14/02/2025 6:39 am
