[Résolu] MK2S + MMU2S separate power supplies
Loenja
(@loenja)
Hi All,
Would it be possible to run the MMU2S unit off a separate 24v power supply as this would reduce the driver whine produced when running the TMCs off 12v.
I was thinking a similar unit to the original power supply but in 24v with a common ground.
Best Answer by Loenja:
Update: I have installed a new 24V psu and it works wonderfully, although it didn't fix my driver issue I asked about on another thread (also fixed btw, by means of a reflow of the area around the TMC chip).
drivers are much quieter now!
Publié : 26/11/2020 6:37 pm
RE: MK2S + MMU2S separate power supplies
that should be possible, as long as the grounds are common. however the higher voltage will only address the MMU2 motors / drivers, not the Mk2.5 motors/drivers
Publié : 26/11/2020 8:34 pm
Loenja
(@loenja)
Posted by: @joantabb
They are the only ones whining at the moment, so perfect.
Publié : 26/11/2020 9:04 pm
Good Luck!
Joan
Publié : 27/11/2020 8:43 pm
Loenja
(@loenja)
Update: MK2S + MMU2S separate power supplies
Publié : 03/12/2020 2:51 pm
1 personnes ont aimé
Chris P
(@chris-p-4)
how to do the wiring
Posted by: @loenja
How did you do the wiring? I'm trying to solve a power issue with the MMU2S with a spare powersupply I have lying around, but unsure how to set up the  wiring?
any help is appriciated! thanks!
Publié : 22/07/2021 3:58 pm
Loenja
(@loenja)
Dual PSU wiring
Posted by: @cowboyhenk
Posted by: @loenja
Connect the Ground of the 12V supply to the ground of the 24V supply.
Connect everything as usual.
Publié : 22/07/2021 10:22 pm
Chris P
(@chris-p-4)
DUAL PSU Wiring
Posted by: @loenja
Thanks!! In my case I used a second 24 volt power supply, but this works like a charm! Reset of the unit still happens though 🙁
Publié : 29/07/2021 8:49 am
RA 2 Storm
(@ra-2-storm)
What AMP power supply would I need?
Publié : 22/02/2023 7:00 pm
