M118 Command
Rick
 Rick
(@rick-3)
M118 Command
Does MK3S support M118 command, I'm trying to use action commands for octoprint to send SMS when filament needs to be changed but can't get it to work. Very little info online about m118 command and support of it? Thanks!
Opublikowany : 30/10/2020 9:48 pm
RE: M118 Command
https://prusa3d.github.io/Prusa-Firmware-Doc/group__GCodes.html
Opublikowany : 30/10/2020 9:50 pm
Rick
 Rick
(@rick-3)
RE: M118 Command
That looks like a no? Do they have plans of supporting the m118 command for MK3s, would be a very helpful !
Opublikowany : 30/10/2020 9:53 pm
RE: M118 Command
You can search for prior requests and if they aren't thinking about it put in a feature request over at github.
Opublikowany : 30/10/2020 9:58 pm
RE: M118 Command
@rickscncdesigns
Another possibility would be to read the remaining amount of filament from the Filament Manager or similar  plugin database and send a warning via SMTP.
Opublikowany : 30/10/2020 11:03 pm
Rick
 Rick
(@rick-3)
RE: M118 Command
@karl-herbert
I actually wanted to use it when I have a color change so I can swap the filament not so much when it runs out.
Opublikowany : 30/10/2020 11:06 pm
RE: M118 Command
My understanding is that the Mk3 firmware is pushing the limits of available memory, so I wouldn't expect too many enhancements that don't impact fundamental printing issues. It can't hurt to put in a feature request over on the Prusa GitHub pages.
Opublikowany : 30/10/2020 11:48 pm
Rick
 Rick
(@rick-3)
RE: M118 Command
@bobstro
Thanks, I have made the request, sounds like it's time for a 32 bit processor on the MK3s.
Opublikowany : 30/10/2020 11:50 pm
newtag
(@newtag)
RE: M118 Command
M118 support is now provided with few 3.13.3 on mk3. Who can say what can be done with this ? I do not find any documentation!
Opublikowany : 02/05/2024 5:27 pm
